sump nut key
sump nut key
what size is it and can you get just the one you need ? or do you have to buy the silly halfords set for £20.00 containing 4 or 5 you know you will never use.
any known alternative to the proper tool ?
thanks
Re: sump nut key
8mm and I bought mine separately from Halfords.
BX-pert
Re: sump nut key
Post by BX-pert »
Yep, 8mm, I ground 2mm off 2 adjacent sides of a length of 10mm key-steel, then clamped it in moles. Good enough. (Or grind down an old 3/8 short extension)
Re: sump nut key
Post by kiwi »
Just point out that there are at least two differant sump bolt types fitted. Helpful to know if it is a Hex, square insert or whatever.
1990 BX19 TZS Auto 06/11/1989
Re: sump nut key
Im another one whos peed off with Halfrauds at the moment, went to get a key all they had was a pack of five
Re: sump nut key
oh sorry , yes its a square one insert one
Re: sump nut key
Yup. Same as mine. 8mm Square one.
Re: sump nut key
Post by RxBX »
Mickey taker wrote:oh sorry , yes its a square one insert one
That will be 8mm square - A/F then Mick !
Heres just an 8MM with a 3/8 drive or a double end 8mm/13mm type which you use with a 19mm A/F socket/spanner :wink:
Re: sump nut key
Post by kiwi »
Mickey taker wrote:Im another one whos peed off with Halfrauds at the moment, went to get a key all they had was a pack of five
I beat you on that I purchased a pack of 8 from one of our equvilants to Halfrauds called Ripco.
Re: sump nut key
and if it were a hex that is 21mm :wink: ( AF not [-X )
Gibbo2286
Re: sump nut key
Post by Gibbo2286 »
Just for your info the square shaft that joins the inner and outer knobs on your house doors is 8mm and can be bought at any diy or ironmongers shop, or if it's Sunday afternoon and you're stuck borrow one out ot the kitchen door. :o
Re: sump nut key
Got mine on Ebay.
Re: sump nut key
the halfords I pass every day only had the set, the other brnch near MK city centre had the right one in stock for under a fiver, door handle rod would have been a good option though.
Thanks everyone
x 103
Re: sump nut key
grinder, wheel bolt, 5 minutes, its all you need.
Re: sump nut key
Vanny wrote:grinder, trip to A&E, stitches, several return visits to hospital, lots of cool drugs and week sat in your boxers drinking ale and swearing a lot. wheel bolt, 5 minutes, its all you need.
edited for accuracy!
