Wanted - ABS rear wheel bearing
Wooscary
Post by Wooscary »
Hello
The garage are having a hard time tracking one down, so while they continue to search, thought I'd ask here
if anyone has one or knows of a source that I can point them at.
x 82
Contact:
Re: Wanted - ABS rear wheel bearing
It's a bearing, so is it not just a case of measuring it and ordering a suitable replacement?
The last wheel bearings and a lot of seals i had came from Borders Pumps and Bearings, local place, who matched the part number on the race to an off the shelf standard part, though i don't think it was SKF
They've also sorted me with bearing seals in the past where Citroen dont stock them any more.
EDIT
Also, they normally come in the hub, so might be worth looking for a complete hub. Perhaps the Xantia or the C5 hub/bearing would do as they are all quite similar (the estates are different).
Contact:
Xantia's have different ABS rings, but I've never looked into whether it could be replaced with a BX ring, I'm not sure the hub is indentical dimensions?
Wooscary
Post by Wooscary »
Cheers for the input. They managed to find one in the end. :)
