Inner wing
barry badger
Inner wing
Post by barry badger »
I'm in the process of dealing with some very nasty rot on the txd. The os inner wing is in tatters, It's so bad i would like to replace it if possible but my local dealer says it's nla. I seem to recall this topic coming up recently and that one inner wing was still available, does anyone have the part numbers and any illustrations of the panel.Incidentally this car had a new inner wing and front panel in 1997 due to accident damage and every single welded joint on these panels is rotten.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
Re: Inner wing
Sounds like either the welds weren't properly cleaned up before paint, or it got too hot, altering the composition of the metal, although that usually only happens with gas welding, which isn't used much these days.
If the panels aren't available, you may be able to salvage a repairable section from a car being broken up.
NeilGP
Re: Inner wing
Post by NeilGP »
I have a new 95-615-413 O/S inner wing in my garage. Is this what you are looking for?
Neil
A476 RBX
Series 1 BX 16TRS
Re: Inner wing
the inner wing is made up out of two main parts inner and outer section
here is price and part No.'s for the O/S/F
95615413 WING INNER FRAM 59.79 GBP 71.75 GBP 71.75 GBP
95645961 WHEEL HOUSING 201.48 GBP 241.78 GBP 241.78 GBP
the first one being the one Neil has which fits in the same plane as the outer wing
the second being the section with the strut turret and down to the chassis rail
barry badger
Re: Inner wing
Thanks Neil/Malcolm
95615413 is the part that I'm after, would you be willing to part with it.
If so name your price!
Barry
NeilGP
Re: Inner wing
Post by NeilGP »
PM'ed
Neil
A476 RBX
Series 1 BX 16TRS
