14re gear linkage
mike22861
14re gear linkage
Post by mike22861 »
Has anyone got a linkage off the Dauvrin engine it's the alloy pivot point that mounts on the back of the box for lateral shift I'm after ie the lever that selects 1st and 2nd or 3rd and 4th or 5th and reverse don't mind buying the whole engine / gearbox or just the part I getting one made but it's taking time
1992 BX 4x4 Gti aircon Silver
some other newer Nissans
Re: 14re gear linkage
if this is the XW lay back type engine/box as in the Visa/early C15
here is price and part No. for the cast alloy bit one of the link rods connects to that usually breaks
7946004382 LEVER 22.67 GBP 27.20 GBP 27.20 GBP
no longer available from citroen but you could try Dean Hunter at peugeot parts with that part No.
Birotor
Post by Birotor »
The 14RE as in my one time owned C reg BX 14RE had the Visa engine...
mike22861
Post by mike22861 »
Thanks for that its an e reg 14RE but yeah the laid back unstressed easy to work on engine
mike22861
Post by mike22861 »
Sadly even peugeot parts couldnt turn one up looks like a make it yourself kind of job.
it was this pug spares you tried and not pug main dealer
http://www.peugeotparts.co.uk/" onclick="window.open(this.href);return false;
otherwise ask again on here as most Visa's have these
http://visaforum.freeforums.org/ucp.php?mode=login" onclick="window.open(this.href);return false;
