hard front end
the citroenman
hard front end
Post by the citroenman »
put new wishbone ball joints on the front and new wishbone rubbers on but the car is hard i now feel a bad vibrating on the drivers wheel and a bad knock i put new drop links new track rod ends do the wishbones need to be in a level position on locking the two nuts back up and new spheres
Re: hard front end
hi and welcome
you should always have the car at its normal driving level when finally tightening wishbone bush's,
so have you fitted new spheres and what brand and where were they purchased
as it is usually flat spheres that cause hard suspension,
although there has recently been an exception to this on one of Andy's (mothman) fleet
were he fitted new spheres then could not get the suspension back down, turned out to be ( after lots of discussion's ) to be a seized front strut ( very un/common )
also is the car riding at its correct height when set in the normal position ( wide white bar at height lever )
