breaking TZD saloon H registration
rabbercelt
I am currently breaking my red TZD saloon,taking parts off before scrapping.If anyone wants anything,let me know,It wont be around for long.
Re: breaking TZD saloon H registration
Could I grab the dipstick and passenger sun visor please? I'd also be interested in the ABS sensors if fitted and you have the chance to take them off.
If you could let me know a price including postage via PM that would be great.
Hi,
i would be interested in the ducting/soundproofing under the bonnet.
In fact the whole bonnet with it still attached would probably be a good idea but not sure how to get it from you as ime in Sussex.Carriage could be expensive.
mike22861
I'd be interested in the drivers door and the front wiper arm and washer bar pm me with a price please
1992 BX 4x4 Gti aircon Silver
some other newer Nissans
what colour is she as im after a two tone TZD front bumper red lower half grey upper,
also is the rubber strip either side of the hand brake good, if so i would like the center consul with this attached,
please pm with price if you have these
bigmaclf
hi woud be interester in the glovebox . if the trim is black tel 07403991551
cacaolat
I think we would need some information about colour and trim here.
I am looking for a rear bumper, but only if it is the right colour which is dark grey.
rabbercelt
The trim is black,door panels and seats are grey and black rear bumper is not for sale but is red anyway.
- x 116
I am after a few bits too.
Assuming it has power steering there is a clip, usually white plastic, which holds the u shaped hydraulic hose pipe that goes between the flow distributor and the pressure regulator. It sits on the LHS beneath the radiator and air filter and clips into the chassis leg. It might be tricky to remove without breaking it but I really need one. Mine is missing and the pipe makes a continual rattling noise which cant be doing the pipe any good as well as driving me mad too.
Also another difficult one. The Y or T connector which joins together the hydraulic leak back pipes from the rear suspension.
It sits above the transverse tube part of the rear subframe at the RH end. Just follow the suspension strut return pipe, a 4mm clear plastic one. They become fragile with age so its best to cut the pipes to get it out.
Payment is not a problem - so thanks in advance.
rabbercelt
Well I seem to have helped some people out-obviously lots more hard to come by parts available.If anyone is interested I have a 1.9 d complete with gearbox which came out of a zx with 87000 miles
regards
Graeme
regards
Graeme
cacaolat
Hi I would really need Part 96011352 linkage to front height adjuster. I thought I have ordered and paid for it, but now they told me they no longer have it (waste of time).
Please let me know if you could take this one off the car.
Mike E (uk)
If you are removing that rod (see above post) could you also remove the height corrector and sell it to me please.
thanks
Mike
thanks
Mike
Ant
Hi,
do you have 4 BX wheel trims and fittong rings?
many thanks
Ant
many thanks
Ant
I need a good interior mirror please, the glass needs to be perfect please with no hazing or damage and not be "wobbly" on the mounting.
Thanks
Thanks
Can you pm me for a price for the hydraulic pump (is the steering nice & smooth? if not then the pump is probably on the way out), & the front & rear struts if in good nick? Cheers
