Electric mirror switch and centre dash tray in black
- x 94
Both needed for my red 16v - let me know what you got.
Re: Electric mirror switch and centre dash tray in black
Might have a centre dash tray in black. Needs a bit of a clean but seems sound.
There is an electric mirror switch currently on feebay at 2.99 i believe. 1 bidder so far. Sorry, i dont have the link.
- x 94
Dolly: Sounds good, let me know what you want for it?
Moth: Will check it out, cheers.
I've got both if the above deals fall through.
Bear in mind that it'll probably be a twin electric mirror switch that Kitch will be after, and the standard mirror switch will not work correctly. I have a standard one I modified to operate both, but I fitted the proper switch a couple of years back. If it still works you can have it, but not sure if the bulbs work.
The one I have is for a TZD, so I assume it will operate drivers side only?mat_fenwick wrote:Bear in mind that it'll probably be a twin electric mirror switch that Kitch will be after, and the standard mirror switch will not work correctly. I have a standard one I modified to operate both, but I fitted the proper switch a couple of years back. If it still works you can have it, but not sure if the bulbs work.
Probably passenger side only? I know that if you put an electric mirror on the driver's side in a TZD, the switch will actually operate both sides at once, presumably so RHD and LHD versions could share the same loom.
- x 94
Sorry should have mentioned it's a twin one I need.
Yep. That would be passenger side wouldn't it!mat_fenwick wrote:Probably passenger side only? I know that if you put an electric mirror on the driver's side in a TZD, the switch will actually operate both sides at once, presumably so RHD and LHD versions could share the same loom.
Does a fiver including postage seem ok? I'm guessing it won't cost much to send.
- x 94
Yeah that's fine mate, pm me how you want me to settle up.
Hi Kitch,
If your still in need of the Electric mirror switch ?
Theres one on E-BAY still available, currently with zero bids and only few hours to the listing ending
Mike E (uk)
I have a dash tray here if you still need one.
Mike
Mike
