Front windows clip on bottom channel with or without glass
x 116
As above for drivers door as mine has rusted away. Its the bit that clips itself onto the bottom edge of the door window.
Its the same part for both sides but the rear doors are different (shorter).
Replacement parts used to be in ally but its usually steel ones fitted in the cars at manufacture.
It can be with or without the door glass from either side which is (ideally) green tinted.
Does anyone have the Cit part no. and/or know if its still available ??
This is our daily use BX so window currently wedged and supported shut so car is still usable
Re: Front windows clip on bottom channel with or without gla
Post by Mothman »
Havnt got the part no but its still available from a main stealer. Dont forget the rubber strip either or it will pop out in a matter of weeks.
Post by RxBX »
Jaba wrote:As above for drivers door as mine has rusted away. Its the bit that clips itself onto the bottom edge of the door window.
Citroën part number 95 633 346 :wink:
Hi Jaba,
Also check out these threads 'PESKY WINDOWS' and 'WINDOW LIFTING CHANNEL'
I hope the /\ is of help to you/others !
:D
x 116
Big surpise, they are available. Ordered today from Hartwells Abingdon @16.93+vat.
So as long as it turns up the search is over.
BXnut
Post by BXnut »
Excellent info everyone. Glad I've joined here now. Off to Citroen in Gloucester, in the morning, as I like to see their faces trying to order BX parts ;)
If that's Warners, they'll wonder what's going on, as I've been a regular there the last couple of weeks :D
They don't have much in stock, but if they can get it they can usually get it in a day or 2, although I have needed to help with pointing at menu screens on the parts system sometimes as they don't know where to look :roll:
