Poorly Red Baron
mike22861
Poorly Red Baron
Post by mike22861 »
The Red Baron has decided that the Activa is receiving far too much attention and decided to throw a sulk too it's leaking lots of Diesel from the injector pump and also leaking lots of air into the injector pump making starting a task and running smelly. If I had time to do it just needs a new seal kit but it may have to be sent off for some mechanics touch.
I will let you know how it gets on.
1992 BX 4x4 Gti aircon Silver
some other newer Nissans
Re: Poorly Red Baron
Bosch pump?
mike22861
Post by mike22861 »
Lucas
KevR
Post by KevR »
Probably just needs a couple of new o-rings on the throttle spindle then. I did mine in situ at new year - took about ten minutes and hasn't given any bother since. Didn't even need to bleed the system afterwards.
the first thing to check is the one way valve's in the banjo unions on the feed/return connections at the pump,
if they get stuck it can cause to much back presure then push fuel out were ever it can,
even if the seals hold normally,
JayW
x 13
Post by JayW »
If it's anything more seroius I have an N/A Lucas Pump sat here in a box with pipes & injectors.
It's not mine, but it is for sale.
mike22861
Post by mike22861 »
Cheers for that Jay but I agree with Tim spindle O rings normal repair on a lucas pump
Post by RxBX »
mike22861 wrote:Cheers for that Jay but I agree with Tim spindle O rings normal repair on a lucas pump
KevR wrote:Probably just needs a couple of new o-rings on the throttle spindle then. I did mine in situ at new year - took about ten minutes and hasn't given any bother since. Didn't even need to bleed the system afterwards.
Mike I take it you meant KevR !
:lol:
mike22861
Post by mike22861 »
sorry yes KevR
