How do you change the side indicator bulbs?
I had a look & tried twisting the lens, but didn't want to try too hard incase something broke, what's the technique for getting them out so that i can change the bulb. In all the years that i've had a BX, this is the 1st one that i've had to do.
Re: How do you change the side indicator bulbs?
It just twists, try giving it a spray with WD or silicone lubricant first.
Nice one Mark, i'll give that a try, i thought it must be something simple, but didn't want to risk busting it without double checking 1st.
Does it matter which way you twist it?
I think as you look at it it twists to the left, I took mine off to spray the inner wings with waxoyl. IIRC the bulb is a W5W push in jobby.
Yeah anticlockwise IIRC
Nice one guy's, i'll have a go with some spray & start twisting
Birotor
I have a 1990 right hand indicator unit to change as it is cracked... Any thoughts? It came with a loose bolt in the packing in the box.....?
It worked, see my blog update
