Cylinder Head for 1700 Diesel Turbo WANTED
ARedOne
Post by ARedOne »
Hi,
After 50,000 miles the cylinder head gasket has gone....
Advice from my local garage - the head is slightly warped - so will probably go again (after 50,000 miles?) If re-fitted. Has anyone got a good condition one?
I am in Bristol, but working in Chelmsford - so either or on route would be great! !
A Red one a White One
Re: Cylinder Head for 1700 Diesel Turbo WANTED
Post by Mothman »
Could it be skimmed?
ARedOne
Post by ARedOne »
Could be - but I have not a clue as to if that would cost nearly as much as a re-con!
Gibbo2286
Post by Gibbo2286 »
It may be worth giving John here a call, he has a lot of stuff in his sheds including heads and camshafts etc. it is however a bit like the old fashioned breakers yard and you'll have to know what you want and probably sort it out for yourself.
http://www.deantruckrepairs.co.uk/" onclick="window.open(this.href);return false;
themildbunch
Post by themildbunch »
I have a TD that is very ill and a spare head but I'm probably going to rebuild this but not 100% sure yet as I'm moving soon so lots going on...
I could be corrected here but it's not generally a good idea to put any spare head on without skimming the head to be 100% it's flat and checking for cracks, etc... IMO given the work getting a TD head off and on again it's worth doing it with a head you can be really confident in...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
I'd always get a head checked unless I knew exactly where it came from. The last head swap I did was on a Reliant. I stripped the head as much as I could and took it to a machine shop in Stonehouse (I forget which one) which specialised in head work - they checked and skimmed it for around £25 (6 years ago).
I wouldn't skim a head as a matter of course, just in case any shallow porosity is uncovered, but it's a simple enough to check if it's required and skim if needed. The last time I had a head skimmed (nearly 4 years ago) it was also £25, and another £25 for a pressure test to make sure there were no cracks.
Rommel
Post by Rommel »
http://www.ebay.co.uk/itm/320971728741? ... 1423.l2649" onclick="window.open(this.href);return false;
Try this guy? He told me he has 2 sitting around.....worth a shot.
There's the 3 TZDs Shaun and I are breaking - all have good engines.
