I am going to have a go at replacing the switch on my sunroof but I know that the mechanism is very stiff so before I burn out the motor can anyone tell me what to lubricate it with and how best to apply lubricant. I don't have the skills to remove the sunroof to do this, is there a quick fix that I can do?
Thanks, Jane
Sunroof lubrication
merlyn
Sunroof lubrication
(now sadly gone)
(now sadly gone)
themildbunch
Re: Sunroof lubrication
mine was stiff too and had lots of debris / bits of leaves etc... I cleaned out the plastic runners, degreased them then used some silicone grease on the plastic runners - made it work a lot smoother...
Maybe teflon splay would be better though as too much grease will attract dirt especially in an exposed flat position like the sunroof
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
merlyn
Well I opened it fully today (both ways) and sprayed some silicone into it. Hope that will help things along. No leaves or other debris that I could see. Hope the switch is all that it needs!
(now sadly gone)
(now sadly gone)
