TRS currently in spot light, as GT may have to go in hiatus, so timing belt/tensioner replacement and (cosmetically) the Pram handle spoiler will come off..
Any one know how these "babies" are attached (pun intended)..Are they bolted on or attached with goop?
Pram Handle removal
B-Hive
Pram Handle removal
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
Re: Pram Handle removal
Bolted through the boot lid, holes covered with grommets IIRC. I tried to remove mine but I think the captive nuts started to turn in the fibre glass so I stopped.
4 bolts yes, 2 under grommets on the bottom side of the lid, 2 are through the plastic cappings that run up the lid either side of the glass
