Cam Belt options?
JayW
x 13
Cam Belt options?
Post by JayW »
The cambelt for my Athena is 17mm x 114 teeth.
Does anyone know if the crank pully is matched to that 17mm or if it's the standard 25mm one (as per the XU9D)?
If it is then does anyone know of an alternative 25mm x 114 teeth belt?
17mm just seems a little weak if a 25mm alternative can be sourced as the cam pulley, water pump and tensioner are all 25mm.
Re: Cam Belt options?
I may have a cambelt that'll fit if you're interested, i'll need to double check though. The Athena is a 1.6 petrol?
You seem a little paranoid about your cambelt breaking? :lol:
JayW
x 13
Post by JayW »
Paranoid, who me? :lol:
I'm changing it anyway so i'd rather upgade if there's the option.
The 17mm just seems a bit on the puny side and i can think of no reason why they didn't spec the 25mm like the rest of them!?!
Matthew, i've got a spare one here so no need, but thanks. There are a number of lengths for the 1600cc, 108, 111, and my 114 teeth.
No worries :) I can measure the one that i have if you want?
JayW
x 13
Post by JayW »
MULLEY wrote:No worries :) I can measure the one that i have if you want?
Will you be measuring the belt too? :wink:
:lol:
