My Bx is for sale as spares or repair.
This is a lhd diesel and it is in the Dordogne.
I am open to offers
1993 BX for sale
smiffy1071
- pies are evil!
Re: 1993 BX for sale
I'd like a pair of LHD headlights if you want to sell them...
- BXpat
/\ Smiffy, I could do you a set of LHD headlights - I've got enough of the things to take on the Blackpool illuminations. The only issue is how? and when? Just had the surreptitious hand-over of BX parts in a French forest with Mat F. so have to wait til the next courier or I come over to U of K ( If I can remember where it is).
Easy - just get yourself to Paris this weekend, a mere 650 kms and I'll bring back BX parts to Blighty!toddao wrote:The only issue is how? and when?
The other option would be to copy Jaba's idea, and carry out a modification to allow switching between RH and LH dip. He did show me, and it was obvious when pointed out. The gist of it was that in the UK position the bulb was hard up against its locating tabs in one direction, and for the Euro position it needed to be rotated in the opposite direction. I'm pretty sure that by removing one of the tabs on the bulb it gave you enough rotational movement with the remaining tabs to do this, but it should be obvious when you look at it.
I guess that there will be still some extra unwanted scatter from the different lens patterns, but he's regularly between countries and said he's had no problems.
smiffy1071
- pies are evil!
but wouldn't that take longer to adjust the bulbs than it would to just swap the whole headlamp?
