sounds like the staff at my work too!Tim Leech wrote:Someone said to me if the turbos whines it means its working!
Dollywobbler's 17TXD Turbo - new home time
Re: Dollywobbler's 17TXD Turbo
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
Cool. I won't worry about that then. Have had to nip out to do some of that tiresome work stuff today, so leapt into the Bluebird as it clonks much less than the BX. Nowhere near as nice to drive! Where's all of the torque?!
Just been having a closer look at the front end. Haven't found any play in the balljoints, but there's a very definite clunk if I pull on the track rod, at the rack end. What needs replacing here?
Also discovered that BOTH strut return pipes are knackered, though only one pipe each side, and it's a different one each side. There's enough LHM spray on the passenger side to coat the inside of the tyre - another source of LHM loss and I suspect a rather larger one than the occasional drip from the regulator. Bother. I hate strut returns. You can't see what you're doing and I can never get that bloody clip to fasten.
On the plus side, the front discs and pads look fresh and this car starts beautifully. Front struts are creaky though.
Ugh. Left hand strut return.
Out-of-focus right hand strut return.
RH brake pad imbalance. Sliders I guess, though I think the handbrake cable might also be a bit sticky.
No rot here though! RH below washer bottle.
There may be some camber issues...
Plenty to be getting on with. While I was at it, I pulled off the sill covers and squirted plenty of waxy anti-rust gunk about the place.
Have managed to get the screenwash pump working (loose connection) but not getting any screenwash. Not sure if it's pump or the spindle being blocked yet. Now has a rear wiper blade fitted. Forgot how annoying the rear wiper is on a hatch. Stupid design! Not quite as stupid as the faff necessary to change a wiper blade. I found it easier to remove the wiper arm. Stupid pram handle!
- My Cars: LOTS!
- x 123
Oppps those arm bearings are toasted!
It certainly explains the creaking from the rear! It'll be transformed after a bit of work.
Have now fitted the Volkswagen wiper relay but still haven't got the washer working yet.
- BXpat
I've missed a few things here.. Nissan Bluebird? Any pics? Glad you're staying with the BX underworld though with your new puchase Ian! Why are you getting rid of the splitter then?
The strut returns are simple with the right tool ( I cannot believe I wasted so much time in the past on what can be five minute job!):
Available from Do-a-Deal- Dave and other less reputable firms!
- My Cars: LOTS!
- x 123
Ian the splitter will leave holes in the bumper when removed which will look pants, so if it were me I would leave it on (same about the wheels too, I think they look great).
My car, my rules. Bumper negotiations are already ongoing and the alloys MUST go.
Todd - we've got a tool similar to that, but I still couldn't get the clip on. Oh well. With both to do, maybe I'll crack it this time!
Hmmm. That was a bit grumpy of me. Sorry!
Anyway. I've now got the screenwash working. Thankfully, shoving a big, straightened paperclip down the wiper spindle with vigour got it working again. I also put some rust converter around the sunroof edge. There is just a hint of orange on the front edge, where the roof skin is folded over. The switch still seems a bit temperamental. Anyone had any joy pulling one apart and cleaning the contacts?
For something a bit different, I fitted the door-open unit that I had in my box of random BX spares. Not wired in though - is there a plug hiding behind the centre of the dash somewhere or was the loom modified for those that had this fitted from new? Still looks better than a blank panel...
I also discovered that one of the handbrake cables is utterly stuffed. The plastic is rock hard and broken in several places and the handbrake just won't release that side. I put a plea out for a replacement, but I note that GSF sell new ones for all of £12.74, so I'll go that route I guess.
- My Cars: LOTS!
- x 123
I did think you were getting a bit wound up, again your car of course, but without a splitter the row of holes it would look daft.
- BXpat
Ian wrote
It funny to have someone who actually wants shot of their splitter rather than trying to find one to fit!
'similar' probably isn't good enough! The return clips are made by 'Clic' and that is the tool for them - it really is easy with that thing.Todd - we've got a tool similar to that, but I still couldn't get the clip on.
The plan is to change the bumper entirely, so the holes just aren't an issue. I thought taking it back to how it should be would be applauded. What controversy!
Anyway, here's some examples of the knackered paint.
The French really were hopeless at making metallic paint stick to plastic. See Renault Espace for more examples.
This caliper slider really wasn't keen on sliding. Knackered boots caused this. How do you get the boots out?! I may have a good, working caliper to try instead as an alternative.
Handbrake cable is utterly broken.
So, this is going to take longer to get back on the road than I expected. Oh well. All ensures I know exactly where I am with this thing when it's all sorted.
You may be unlucky thereFor something a bit different, I fitted the door-open unit that I had in my box of random BX spares. Not wired in though - is there a plug hiding behind the centre of the dash somewhere or was the loom modified for those that had this fitted from new? Still looks better than a blank panel...
If I had known you could have swapped the bluebird for my meteor and saved yourself a lot of work lol
