Lock Set
Re: Lock Set
Non central locking kit - that's gotta be rare! doesn't fit mine, which is just as well as it's gone already!
Re: Lock Set
That was bloody quick Goooooooooooone and I also noticed that the same seller had just the steering lock set TOO but was sold on the 13th Sept
Well done who ever got in there
I take it it was someone from the BXC forum ?
Edit:- just seen that theres another steering lock/barrel listed by the same seller, heres the LINK good luck if you secure this one !
- x 94
barry badger
Re: Lock Set
I bought the ignition barrel, it doesn't have the small green wire but hopefully that is the only difference to the ones fitted to my diesels. I've not compared it to an old one yet.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
Re: Lock Set
The Green wire is only needed if you vehicle has ABS fitted, if it does have ABS just transfer the Green feed wire from the vehicle with a failed lock and 'Bob's your Aunty'barry badger wrote:I bought the ignition barrel, it doesn't have the small green wire but hopefully that is the only difference to the ones fitted to my diesels. I've not compared it to an old one yet.
Re: Lock Set
/\ Don't you mean "It is completely incompatible with an ABS vehicle therefore you should sell it to someone else?"
