dial indicator bracketry for diesel timing
I've found a couple of dial indicators coming from Ebay for setting up Timex's injection pump, but will need to make up the bracketry for mounting them. I just wondered if someone's done this before or has pics of the mounts in place - Haynes (as usual) is less than clear on the details.
As Andy Weston spotted an '85' stamped on the pump, I'm working on the assumption that this is the original pump, which is set using 1 indicator for pump position and a 2nd for engine position.
barry badger
Re: dial indicator bracketry for diesel timing
Post by barry badger »
I have all of the brackets and a dial gauge for the pump if you want to borrow them. just cover the postage. I'm not sure but you may be able to use the crankshaft timing pin for tdc instead of a dial gauge?
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
Thanks for the offer - I'm hoping my dial gauges will arrive Monday, so will start work on the brackets then.
If you could post a pic of your bracket I'd be grateful.
According to the Haynes book of lies, the early Bosch pump like mine is timed at 4mm below TDC, not TDC like the other pumps, which is why I need the 2nd indicator, and may explain why mine is out at the moment
barry badger
I'm afraid i can't post any pictures as our computer is in some sort of restricted mode, it needs attention!
Not that i would know how to anyway!
No worries, I'll work it out.
barry badger wrote:I'm afraid i can't post any pictures as our computer is in some sort of restricted mode, it needs attention!
If you can email me Barry I will post them.
barry badger
I'm afraid i can't send any pictures via e mail also, but i am more than happy to lend my timing kit out i'm in no rush for it back at all. I bought it to time my tzd before i discovered the problem was compression not timing. If you need it mike pm me your address and i'll send it straight away.
Thanks for the offer Barry, but I think I've worked out what I'm doing now - watch this space!
