REAR HYDRAULIC PIPE REPLACEMENT
bookman
REAR HYDRAULIC PIPES...can anyone help please...I need to replace one of these ( passenger side just in front of rear wheel),its the second one up from the floor out of 4,I can't find an illustration of these pipes so what is this one for and where does it go ? My car is a BX17 with abs.Is it possible to replace this without dropping the rear end out ? Many thanks,Dave
Re: REAR HYDRAULIC PIPE REPLACEMENT
I think you can replace it without dropping the rear subframe, but my past experience is that if one has gone, the rest may not be far behind. If you plan on keeping this car long term, it may be best to bite the bullet, drop the subframe and change all the front to rear pipes in 1 go
the only way to do front to rear pipes is drop the sub frame,
whilst its down do the two brake and two suspension pipes going across the sub frame also
KevR
Bum.citronut wrote:the only way to do front to rear pipes is drop the sub frame,
Oh well, good excuse to check the arm bearings and seriously rustproof the subframe mounting area while it's out..
Definitely - I have a decent set of pipes etc. on mine, but will have to drop the subframe to repair the mounts properlyseriously rustproof the subframe mounting area while it's out..
