No ignition / battery light
The wife rang up earlier stranded with a flat battery, In ran out with a replacement to get her going but noted there was no ignition / battery light iluminating. I put a meter across the battery and it is not charging. I seam to recall that if the ignition/battery bulb is blown this will break the charging circuit, Is my memory correct or should I be looking elsewhere? I need to try and fix this tonight so any quick replies would be very much appreciated.
Re: No ignition / battery light
You're correct, chances are if you replace this bulb then it will charge again.
Thanks Mat, I'm on with it.
That's today's something new learned - I thought it was only old British stuff which worked that way.
Just swapped bulbs with the water level lamp that was working and no joy, still no battery light
citsncycles wrote:I thought it was only old British stuff which worked that way.
I'd check the small wire is still attached to the back of the alternator then - they can sometimes get brittle with heat/age and break off.
Yes small wire still attached, i've checked the alternator output with the engine running and the main wire is showing current battery voltage of 12.2v and the little wire is showing 11.35v?
EDIT; left it charging overnight so she will have a charged battery for tomorrow then i'll have another look over the weekend.
JayW
- x 13
Try the single wire on the back of the alternator (usually green), it tends to crap up or fall off.
Your other main possibility is the regulator or diode as any other non-charge fault would light the lamp.
JayW
- x 13
Damn my procrastination! Men can multi-task, honestly!
Thanks Jay, I take it the reg is built into the Back of the alternator on a BX? I'll whip the alternator off on Saturday morning, how do I test the regulator & diode?
JayW
- x 13
Yes, the regulator is the black plastic "box" on the back.
Simple diode testing is with a a multimeter. Resistive testing at approx 2k OHM should give reading one way but not the other. Resistance both ways indicates a short & none both ways indicates open.
If any of the windings are shot or the brushes are gone the lamp *should* be lit.
JayW
- x 13
Forgot to add, didoes need to be out of circuit (disconnected) to test.
Also, have you checked the voltage of the exciter wire without the engine running but ignition on?
electrokid
Yes alternator is shot in some way - when charging the battery volts will be in the region of 14v. The 'ign' bulb is driven directly by the little wire connection - AFAIK its operation - or non operation doesn't affect the working of the alternator- it's an output from the alternator only.i've checked the alternator output with the engine running and the main wire is showing current battery voltage of 12.2v and the little wire is showing 11.35v?
If Jay's checks don't prove fruitful then I suggest an eBay search for a replacement.
2002 C5 HDi SX estate
JayW
- x 13
It's always been my understanding that this wire feeds 12v to the field coils (through the idiot lamp) to excite the coils and create the electromagnetic field required to produce power. If this wire is not supplying 12v then the alternator won't charge. Many alternators will self-excite once the revs get high enough (2k-3k).electrokid wrote:[it's an output from the alternator only.
As the bulb has been substituted for a known god this is unlikely to be the fault (unless there is a wiring issue). Most internal alternator faults which stop the production of power return this wire to ground and light the idiot lamp, hence my only suggestion of the diodes.
An alternative to test the wiring to the idiot lamp is to connect a spare dash bulb between this output terminal on the alternator and battery positive which should act exactly as the dash light should. If it does this indicates a wiring fault between the alternator exciter wire and the dash bulb circuit.
electrokid
That used to be one arrangement but not these days AFAIK the lamp connection is just that - an output from the alternator to drive a lamp when there's no alternator output - everything these days is self exciting. (Unless you've got a Granada with a nasty Pierburg electric choke in which case the little wire on the alternator is a 6 volt output to the choke systemIt's always been my understanding that this wire feeds 12v to the field coils (through the idiot lamp) to excite the coils and create the electromagnetic field required to produce power.
Anyway back to solutions to the problem - this eBay item ends tomorrow about midday but it'll probably roll over - very reasonable price.
http://www.ebay.co.uk/itm/190667118300? ... 1438.l2649
