brake lights not working and the steering gaitor had turned into a manky lump of oiled plastic. So, this morning went to Malcolm's in St Leonards and fixed it under his instruction. Bulbs just simple connection /corrosion problems and the gaitor wasnt too bad other than the typical French connector thingy which proved a bastard to undo. Replaced with a cable tie. So, another years motoring in a fantastic motor. You must get one Tim.
