Diesel fuel sender unit wanted NOW Gauge wanted
Does anyone know if they are still available from Citroen? The TZD has been playing up for a while and now drops to zero after initially raising on start up. I have checked the wiring connector on top of the tank and all ok so assume it's the sender unit itself?
Re: Diesel fuel sender unit wanted
Try Paul296 as he & Shaune have a few scrapper BX's, so they might have a spare one available for little money, alternatively BX Bandit is scrapping his car, so might be worth a try? PM is your best friend :)
Post by Mothman »
I had this on my n/a diesel estate. Just really cleaned all the contacts at the top of the tank, had a real go at them with sandpaper and wire wool and it sorted the problem, both the male and female connectors. May be worth a revisit, certainly less hassle than sourcing and replacing a sender unit.
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
It will be the sender itself in all likelihood. Yet again it's a part I'm keeping as it is only a year old and works! A Citroen C15 van uses the same unit....If you take apart the actual sender unit to have a look or repair, be really, really, very, extremely gentle in cleaning the 'zig-zag' conducting strips 'bonded' onto the 'pcb' that sits in the fuel - just look at them and they'll fall off - probably the cause of the failure in the first place!
Still available, wallet now £96 lighter :-|
Mothman wrote:I had this on my n/a diesel estate. Just really cleaned all the contacts at the top of the tank, had a real go at them with sandpaper and wire wool and it sorted the problem, both the male and female connectors. May be worth a revisit, certainly less hassle than sourcing and replacing a sender unit.
Thanks Andy but visited it twice already; the contacts looked perfect but I still went back and tried contact cleaner as well but no joy. Annoying thing is the sender unit is one of the few parts I left on my old TGD I've just scrapped :(
I just removed one from an '85 TRD - was in working order. Too late?
Thanks Tod
I've ordered a new one now which I'm quite happy to do whilst they are still available as I have no plans on getting rid of this car so long term reliability is my priority even if I have to pay a premium. I get a sense of satisfaction out of pampering the old girl as it gives me so much back from my small initial investment and zero depreciation.
here is price and part No.
cough cough :shock: :shock:
92552015 RHEOSTAT 93.96 GBP 112.75 GBP 112.75 GBP
smiffy1071
pies are evil!
Post by smiffy1071 »
It is the same part as for petrol cars too
Brian
Post by Brian »
Hi This is worth a try, it fixed my sender..
http://www.bxclub.co.uk/forum/viewtopic ... highlight=" onclick="window.open(this.href);return false;
Visa 17D 1986 192K Sorn
BX 17TZD 1992 192K
306 XRDT 1996 175K
Thanks Brian, I will give that a try and hopefully have a spare sender unit for my stock. =D>
Re: Diesel fuel sender unit wanted NOW Gauge wanted
Having changed the sender for a new Citroen unit my fuel gauge still isn't working properly (won't go above 1/4) although the new sender reads differently than the old sender? I have also re-wired the wiring plug just to eliminate it but can only assume the problem now lies with the gauge itself.
Has anyone got a fuel gauge / oil level pod unit I can buy?
Post by RxBX »
Defender110 wrote:Having changed the sender for a new Citroën unit my fuel gauge still isn't working properly (won't go above 1/4) although the new sender reads differently than the old sender? I have also re-wired the wiring plug just to eliminate it but can only assume the problem now lies with the gauge itself.
Hi Kevan,
I should have one available, PM sent !
