bx plastic rear wheel arch trim
x 138
Post by rutter123 »
does anyone know where i can get or if available, i need a n/s/r plastic wheel arch trim panel, colour not important but red would be good to fit a 90 tzdt, are these bonded/glued and any tips for removal/refitting would be good.
Re: bx plastic rear wheel arch trim
Post by Mothman »
Arnt they quite difficult to remove?
JayW
x 13
Post by JayW »
They are Sikaflex'd on and there are plastic "wingnuts" on the inside of the arch. A hairdryer to bothe sides of the panel and a bit of patience is required for removal.
Drop "bxbandit" a PM, you'll find a recent post from him in this very section, he's breaking a red one as we speak.
Jayboy
Post by Jayboy »
Do you just mean the one that sits flush at the very front lower corner of the wheel arch? If so they are usually just attached with double sided tape or possibly an adhesive. A bit of heat and gentle persuasion should see it removed quite easily. They have practically fallen off for me in some cases!
I think Jay is referring to the nightmarish 16 Valve arch spats.
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
IOWBX
My Cars: 61 Hillman Minx
65 Sunbeam Alpine
65 Ford F250 pickup
82 Lotus Eclat
90 Renault 5
90 Rover Metro GTi 16v
Post by IOWBX »
is this any good to you on ebay?? item 281025411955
good luck
I like older cars… I love Citroens
Need a BX :D
Nope that's a N/S/F inner wing arch.
