Citroen BX TZD, rear exhaust wanted
halima99
Post by halima99 »
I am in need of a rear exhaust for a 1.9 n/a diesel BX, car is on a J plate .
Re: Citroën BX TZD, rear exhaust wanted
Post by Mothman »
There's tons on ebay bud.
Post by RxBX »
halima99 wrote:I am in need of a rear exhaust for a 1.9 n/a diesel BX, car is on a J plate .
You've not stated if its for an Estate or Hatchback (As they are different ) :wink:
But heres one on E-BAY for a hatchback model for a £27.14 inclusive of delivery if that's of any use !
If its a 19TZD non turbo it cant be an estate.
An estate one will fit, & how do i know this, haha, the garage ordered the wrong one & when it was fitted i mentioned that i don't think the exhaust tail should be 2ft long from the rear bumper, they cut it back to size, hence the sporting look of my straight exhaust rather than the typical downard facing one.
KevR
Post by KevR »
And vice versa - I ran a saloon one on the first estate for years. The only difference is the length of the tailpipe.
Post by Mothman »
KevR wrote:And vice versa - I ran a saloon one on the first estate for years. The only difference is the length of the tailpipe.
Same here but the cabin did fill with exhaust fumes when stationary with the engine running. Now sorted cos after 5 years the old one fell off.
KevR
Post by KevR »
Never noticed that, but then I don't do very much driving in traffic, fortunately!
halima99
Post by halima99 »
It's a hatchback.
x 138
Post by rutter123 »
£3o on ebay or GSF £40 ish should be fairly easy to get one advise fit new rubber hangers too.
Post by Mothman »
Hangers last a long time bud, never replaced any of mine on any motor i have replaced an exhaust. Just an unneccessary expense. That includes the 27 year olds.
Its usually the metal to which the hangers attach that goes.
halima99
Post by halima99 »
Thanks guys, it seems though that the metal attached to the body that holds the hangers has rotted and dropped off.
halima99 wrote:Thanks guys, it seems though that the metal attached to the body that holds the hangers has rotted and dropped off.
They all do that!
