Brakes and mechanics
stuart_hedges
I can't remember if I mentioned it on here or not, but I spent £120 on getting new pads and discs fitted to the front of my BX about three weeks ago.
On Friday night, on my regular trip down to see my girlfriend in Brighton, I was slowing down for a roundabout when there was a puff of smoke from under one of the front wheelarches, followed by a burning smell. I pulled over sharpish and called for a tow.
The recovery diver agreed with me that it was certainly the brakes at fault; he said that burning smell was very characteristic of overheated brake pads. We decided that that one brake must be binding on; but not enough to prevent the car being pushed by one hand. Also, it hadn't affected the car's handling at all.
Even so, he didn't want to take the risk of telling me to carry on so he took me home and I got the train to Brighton.
I have done a good few hundred miles without problems since the work was done, so bad workmanship on the new pads and discs seems unlikely... or does it? What do you think?
there are a number of possible causes - firstly are the pads moving freely or is there a build up of dirt and rust along the edges of the calipers meaning they don't retract properly? Do the calipers slide freely on their runners or, as is common, have they got sticky or stiff? (BX use a single piston sliding caliper on the front - when it gets stiff one pad wears more than the other)
Tthe other possibility is the handbrake - the cable may have been adjusted wrongly, it may have adjusted itself tigheter than usual especially if the operating arm on the caliper was moved back to the end of its travel during the pad fitting, or the cable may be failing and not releasing properly.
Finally - it might be the pads bedding in or even burning off some rust preservative from the new disc that should have been washed off during fitting.
stuart_hedges
Stewart (oily!)
AlanS
Just as well you don't live out here; you could multiply that by 3 and then ad labour to get a ball park figure.Stewart (oily!) wrote:£120 for disc sand pads, Im in the wrong job againDid that include parts?
Stewart
Yep, just did a quick guesstimate and it would cost almost A$540 for parts alone and they'd charge you at least another $120 for labour.
Scarey hey??:shock:
Alan S
Sure hope soStewart (oily!) wrote:£120 for disc sand pads, Im in the wrong job againDid that include parts?
Stewart
As you don't need to remove the calipers or bleed the brakes a garage presumably only needs an hour a side, give or take, that still leaves £87.61 for 2 hours work.
stuart_hedges
I haven't got the receipt to hand so can't tell you exactly, but I do remember it was half and half - 60 for parts and 60 for labour.
It's annoying because it's the kind of job I'd usually do myself, but I just don't have anywhere to work at the moment. I live in a terraced house on a very narrow street
AlanS
If you work quick enough, that shouldn't be a problem.stuart_hedges wrote:I haven't got the receipt to hand so can't tell you exactly, but I do remember it was half and half - 60 for parts and 60 for labour.
Alan S
stuart_hedges
Forgot to say... when I took the car back to the garage this morning I mentioned Jeremy's points in the first reply of the thread, emphasising the handbrake one as the lever is a lot stiffer and lower than it was before the work.
The mechanic said "We wouldn't normally adjust the handbrake when replacing pads and discs."
Oh really?
Oh really?
Hi Stewart, actually this is true as the the calipers and handbrake are self adjusting. So if the cables are OK and there was not a problem before then changing disks and pads should not upset the handbrake.stuart_hedges wrote:The mechanic said "We wouldn't normally adjust the handbrake when replacing pads and discs."
Oh really?
Stuart, I'd keep an eye on the situation if I were you. Once overheated, the seals in the caliper can become baked and hard, allowing fliud to pass.
Also another point worth noting, if the flexible hose is internally damaged, the brakes will come on but may not go off, as the hose may suck flat inside when you take your foot off the pedal, rare but it does happen.
Stewart (oily!)
I have seen an internally collapsing brake hose, the owner was totally perplexed, the brake could be bled but upon driving it stayed on quite hard, the pads sort of melted, the disc turned blue, in the dark it glowed, owner replaces disc, caliper and pads only to get exactly the same fault!
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Way - yes you're right BUT - often you find when you look at the brake that the handbrake operating lever on the caliper can be pushed back a little more and this sometimes seems to tighten the adjustment. Whats happening is that the return spring isn't quite strong enough to pull the mechanism/cable back as far as it can go, and so when its helped (as I would do when changing pads) it takes a better bite as it were.
It'll settle down quickly if this does happen - and then be untraceable!
stuart_hedges
Interesting stuff guys - I'll be keeping an eye on it anyway because we all know these irritating intermittent faults never go away!
I picked the car up from the garage this morning and their report was this: The brake wasn't binding at all when it was in the garage so they can't promise to have fixed it, but they did spot a difference between the affected side and the other and have sorted that.
Apparently there should be a bracket on the strut which holds the handbrake cable and brake flexi-hose in place. This was missing and the cable and hose were held in place with cable-ties. The cable wasn't at the same angle as on the good side, so the mechanic wondered if that misalignment was causing the handbrake to stick on.
He couldn't source the bracket and didn't fancy welding to the fluid-filled strut, so he's bodged something up (I haven't looked yet) to hold the cable at the same angle as on the good side.
So... does anyone know if I can get hold of this mysterious bracket? Or does it come as part of the strut? They creak a little anyway so are on the agenda for replacing - I might just hurry that job up a little (especially if I get my long-promised payrise).
