BX Cylinder Support replacement
shogun
Post by shogun »
Hi, Is possible to find replacement parts for the 95 563 928 Cylinder support for a BX TZD? Thanks
Discoil
Re: BX Cylinder Support replacement
Post by Discoil »
Front or rear ?
Saloon or estate ?
I don't know about others , I don't have a part no. book to hand :?
Land Rover Discovery TD5
shogun
Post by shogun »
It is Front Cyl support number 13 from attached image
For a saloon BX TZD
Thanks
strut support.jpg (39.48 KiB) Viewed 534 times
Discoil
Post by Discoil »
Thanks for the reference piccy .
I recently got some secondhand complete units off this forum . I'm now going off to lock them away :wink:
I'll have a look under the shelf soon and see if I have another one that might be of use.
It might also help if you put this in the For Sale // Wanted section
shogun
Post by shogun »
Will be waitinig yor reply,also will follow your recommendation. Thank you
this part is called a strut top mount and im sure it will be the same from all BX's,
so does not just have to be TZD specific
