Loads of BX Spares
Ian_Fearn
Loads of BX Spares
As many of you know my BX is gone and won't be replaced so my spares hoard is up for grabs.
Hilary Stone has first dibs on it but i'll list it here so everyone can see whats available. I didn't have a huge amount of time to go through everything as its in three locations across Derbyshire so its pretty high level.
Have a read through and if you're interested let me know. I've ZERO idea about price but its more important that it goes in one lot. I'm (hopefully) moving house soon and don't really have the time to sell it off in bits and certainly don't have space for it where we're going.
All mk2 bits
5x TZD wheel trims
Set of new rubber side moulding trims, still in genuine Citroen box
Front subframe (fitted to a car for 1 year then removed)
Genuine part towbar with genuine electrics kit
New track rod end
Front grill, chrome type from a TXS
4x GTi (narrower 8v type), ideally want a refurb but are useable, they came from my old hurricane so I know they are perfectly straight
Sump from my old TZD no provision for oil temp gauge sender
Interior door moulding, the section that contains the front speakers passenger and drivers side
New 1.6 lower radiator hose
Large array of dashboard parts including steering column cowl, clock tray, ash trays, heater panel etc etc. Too much to list in the time I had today
3x Heater mechanism panels
3x Passenger side electric mirrors
Drivers side electric mirror
Manual mirror drivers side
Boot release button
Various washer pumps
Various indicator lenses
4x GTi injectors
Alloy wheel bolts (might be 2 sets?)
Non broken black glovebox
Speedo pod +2 partial speedo panels
Clutch cables (petrol and diesel)
A few indicator switches
A few wiper switches
1x what I think is the interior light timer device screwed to the inner side of the dashboard, black box
Rear wiper, hazard light switches
Large array of switches, relays, fuses etc.
GTi fuel pump
2x driveshafts
Rear suspension arm
2x rear brake calipers
Flow distributor valve
Pressure regulator
2x front struts (done 35,000 miles from my old TZD Turbo), only swapped them because I got virtually given brand new ones
Various used mudflaps
Wiper motor
Electric sunroof motors (more than 1)
Electric window motors (various)
Injector wiring harness
Central locking motor
2x washer bottles
2x ABS control units
GTi throttle body
Upper steering column
Injector rail GTi
Diesel primer
Brand new rear spoiler
GTi coil
GTi ignition module
2x petrol (16v) hydraulic pumps
1x diesel hydraulic pump
3x Heater blowers
ABS sensors (at least one but not sure what position)
Also a windscreen but again, Hilary has first dibs on that.
All mk2 bits
5x TZD wheel trims
New track rod end
Boot release button
4x GTi injectors
GTi fuel pump
2x driveshafts
Rear suspension arm
Pressure regulator
Wiper motor
2x washer bottles
GTi throttle body
Injector rail GTi
Diesel primer
GTi coil
GTi ignition module
3x Heater blowers
Over and out from me
Ian_Fearn
Re: Loads of BX Spares
Also genuine rear headrests (2 sets I think)
Brand new boxed headlights.
IM'msure Sandre will want the black glovebox Ian if you could reserve it until she signs in! It got broken whilst on BXClub business!
Ian_Fearn
Also a slightly tatty but straight Olympic blue rear bumper.
Ian_Fearn wrote:Also a slightly tatty but straight Olympic blue rear bumper.
Ian_Fearn
You can have it back if you want mate!! Its been clogging up my shed for the past 3 years!Tim Leech wrote:Ian_Fearn wrote:Also a slightly tatty but straight Olympic blue rear bumper.
No need for me Ian, but wasnt a lad on here with a 14TGE after one?
Ian_Fearn
Ian_Fearn
Swap the lot for a 2.3 Ford Galaxy plus cash your way???
- Reluctant BXpert
Definitely, if you're willing to split the parts please Ian - if so, please me have a price on the front struts as well? ThanksTim Leech wrote:IM'msure Sandre will want the black glovebox Ian if you could reserve it until she signs in! It got broken whilst on BXClub business!
I can collect them for you Sandre and bring them along to Yaxley.
Ian_Fearn
TizzyD
- x 10
Can I get 1 passenger side electric mirror, 1 heater blower and 1 heater mechanism panel ?
OK Ian, let me know if that changes, I think you may stuggle as people dont have the cash or space to take the lot.
