£40 winter restoration
mark239
Re: £40 winter restoration
Post by mark239 »
BX Bandit wrote:You sure that's a £40 restoration?
Nice work though. How are the throttle bodies on the 16v?
The £40 refers to the price paid for the car, the restoration will be a lot more !
New liners have arrived, will update thread at weekend.
Those pistons are too sexy to hide in an engine! :P
CGATCX25GTITURBO
Post by CGATCX25GTITURBO »
Defender110 wrote:Those pistons are too sexy to hide in an engine! :P
they live in here
missing my 1992 BX19TGD
1987 BX19 GTI 8)
19TD temp 2 Xantia estate :)
600 Bandit 97 :)
ZX12R 00 :evil:
Will that engine fit in a Bx?
x 174
If you have a big enough Hammer anything will fit.
Tim Leech wrote:If you have a big enough Hammer anything will fit.
I suggested this for Marks valver once but I couldn't get him that interested; he said it'd make the interior smell of petrol and be very uncomfortable for passengers! :shock:
Might upset the handling a tad too!
mark239
Post by mark239 »
Good bit done this weekend, new liners in, honed, new piston rings gapped, pistons back in, head back on
Yes, I'm using normal 8V liners!! I know of folks running them in boosted motors with no problems.
Here's the old liners
New oil seals
The stuff to go in
New liner
Gapping the rings
Old liners pulled out, seats cleaned up so they'll actually seal
Putting liners in
All liners in
Compressing rings to put pistons back in
Big ends torqued up
Clamps on
Head cleaning up for reinstall
All pistons back in
Head gasket on, with copper spray (Not necessary but I like it)
Head back on
x 91
That takes me back to when I rebuilt my red 16v's engine back in 2005.
I hope nobody ever fits the cams with the head on the bench, then picks the head up, face down, and repeatedly puts it down again.
Annyoing tapping from freshly rebuilt engine? Slightly bent inlet valve? Complete muppet for 3 years anyone?
mark239
Post by mark239 »
LOL that would be a silly mistake!
Almost like when I was putting my monster MR2 engine back together and realised I'd forgotten to lap the valves in (And the tolerances were wrong to shim out of it) and had to ruin a £300 headgasket!!
x 91
Ah I got away with lapping valves, or not doing it as the case was.
Saxo VTR with a VTS engine fitted. 12 bent valves due to snapped cambelt - buy 16 used valves on eBay from a 106 GTi (same car underneath) and fit 12 of them. I was very pressed for time. New seats? No. New guides? No. New seals? No. Lap the valves in? No.
How did it run? Best dyno pull was 134bhp (standard is 120bhp!) so not only is it running well, it's kicking out some power for some reason too!
Sometimes cutting corners is fine :lol:
mark239
Post by mark239 »
Is the 106 shim under bucket or hydraulic lifter?
3S engine in MR2 is stupid shim under bucket, and I'd new seats in to accomodate the bigger valves and the valve clearances were too far out
mark239
Post by mark239 »
Got less done this weekend than I wanted, as I was bloody sick.
Still got a few things sorted - wiring started, throttle bodles on, timing belt on
where i left it last week
manifold on for throttle bodies
had to take the die grinder to the engine mount to allow manifold to fit
throttle bodies bolted on
home made back plate for the air filter, secured with the trumpets
the tbs fully assembled with linkages
starting the wiring loom for the ECU
before the pulleys and timing cover backplate went on
starting to split looms to decipher the wiring, and work the new ECU into it.
timing cover backplate on, pulleys and timing belt. no tension in the belt yet as waiting on getting a tension gauge for the belt tomorrow before I tighten the tensioners up.
top view of tbs
How much extra horse power should the TB's produce?
mark239
Post by mark239 »
No idea, I'll be mapping it on the road only like I normally do so won't have an accurate figure, I'd guess 10 percent or so more?
I'll likely see biggest benefit from the engine rebuild with the new bores and rings.
