front struts needwd
benben10
front struts needwd
Hi does anyone have front struts for BX17 TZD? NSF needed for MOT
Thanks
Thanks
Re: front struts needwd
hi and welcome
what is wrong/is the MOT tester saying with your original one's
were are you located
benben10
hey Malcolm, thanks for the welcome..... this is a great site.
MOT guy said its leaking and failed the car. luckily MOT is valid to end of Feb
its been too wet to get wheel off and have a good look (no garage)... looking in Haynes manual
and reading here it could be a seal. Any ideas?
im in sunny Leicester
Ben
Ben
Have you checked the strut return pipes are attached first, this is the most common problem of wet struts and very easily/cheaply fixed?
Defender110 wrote:Have you checked the strut return pipes are attached first, this is the most common problem of wet struts and very easily/cheaply fixed?
You beat me to it Kevan, welcome to the site Ben, its very rare for a strut to fail completely, the usual culprit is the strut return pipe as noted, which are about £15 and half an hour to fit.
Im Leicestershire mysellf, im not that great on tech stuff but its nice to have another local chap.
What BX do you drive?
benben10
Thanks for the advice, much apreciated!
Im hoping to get the car in the warehouse at the weekend for a good look around so fingers crossed it is the return pipe.
Only bought the car a week ago, parked at work then wouldnt start, found the ignition barrel was faulty so now has a seperate start button.
May see you around Leicestershire then Tim
benben10 wrote:Thanks for the advice, much apreciated!
Hi Ben
Im in Ashby, let me know if you need anything, this forum is essential (imo) if you want to keep a BX on the road.
Strut return pipes are still available from Citroen last time I checked.
We get together now and again for tech sessions or just general chin wags.
but has recently started getting his hands dirtyTim Leech wrote: Im Leicestershire mysellf, im not that great on tech stuff but its nice to have another local chap.
Yes thats true I have started to dabble with the oily bits with some success. BX's are after all quite simple cars (ignore what the great unwashed say).
Tim Leech wrote:Yes thats true I have started to dabble with the oily bits with some success. BX's are after all quite simple cars (ignore what the great unwashed say).
Except when they wont go and bleed green blood everywhere!!
I can proudly (and perhaps dangerously) say that I have never had a BX leak green blood everywhere and fail to move. I've had the odd minor leak (the TXD still has one) but (grasping at wood) I've never had one go proper leaky.
Dollywobbler wrote:I can proudly (and perhaps dangerously) say that I have never had a BX leak green blood everywhere and fail to move. I've had the odd minor leak (the TXD still has one) but (grasping at wood) I've never had one go proper leaky.
Me too (and ive owned over 30)
Hell, you have been lucky in your BX ownership Ian. I have had many a catastrophic leak where they have bled out in a matter of minutes but still driveable. Ime told you can drive 100 miles before the pump knackers itself. In fact ive done it on 2 occasions driving 80 miles in one case and the pump survived just fine.
didnt Richard ( RxBx ) have a pair of struts for sale ?
If not there was one in the boot of the meteor that I sold to Adam , he may be willing to sell it
I've had a front strut "let go" and the pressure is enough to blow the strut returns apart which means that you can't get it home even with some nursing.Dollywobbler wrote:I can proudly (and perhaps dangerously) say that I have never had a BX leak green blood everywhere and fail to move. I've had the odd minor leak (the TXD still has one) but (grasping at wood) I've never had one go proper leaky.
