Wanted, battery securing clamp.
saintjamesy89
My Cars: 1985 Citroen BX19 GT
1990 Volvo 740 2.3 GLE Estate
2013 Nissan Leaf Acenta 24Kw
x 196
Post by saintjamesy89 »
As the title, my GT doesn't have one, and the engine earth strap is unnattached (I believe it should attach to the clamp securing bolt). I suppose I could bodge one together, but it's a special car so would like the real and proper thing :)
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
Re: Wanted, battery securing clamp.
They are the same on all BX's Tom so im sure someone should have one?
These clamp on the base of the battery don't they? if so, I've used a Saxo one (couple of quid on Ebay) on the GS which was missing a clamp.
Post by Mothman »
saintjamesy89 wrote:As the title, my GT doesn't have one, and the engine earth strap is unnattached (I believe it should attach to the clamp securing bolt). I suppose I could bodge one together, but it's a special car so would like the real and proper thing :)
Ime sure the earth strap should not attach to the batt clamp bud, havnt seen a BX with that set up. Should attach to the bulkhead just below and to the side of the batt. Just cleaned up Sophie's and its made a magnificent difference and all the lights work so much better and the starter motor is much faster.
I did have a spare but had to use it on Sophie. however ime sure someone will have one and ime sure you realise its an MOT failure now to be without one.
Erm, on all 4 of mine theres an earth strap with a lollipop end with a hole in it that fits round the bolt that holds the clamp tight against the battery itself.
Post by Mothman »
Tim Leech wrote:Erm, on all 4 of mine theres an earth strap with a lollipop end with a hole in it that fits round the bolt that holds the clamp tight against the battery itself.
Dosnt seem to be any on mine Tim, the earth strap fits directly to the body along with 2 other lollipops. Its what i cleaned up on Sophie the other day. There was nothing on the batt holder and its not there on any of my BXs
Gary
Post by Gary »
It is not the main earth lead Andy, but a supplementary lead from the gearbox case to the battery clamp.
It is not fitted to either of my diesels but is on both of the GTi's I have and it was also fitted on the GT I had a few years ago.
1992 BX GTi Hurricane x2
1991 BX Meteor 1.9d
1993 BX TXD Turbo, Ice blue
1987 Visa GTi
Probably just fitted to petrols then?
Tim Leech wrote:Probably just fitted to petrols then?
None of my diesels have had this so I guess so.
