TD clutch in 16v?
djoptix
TD clutch in 16v?
Seen this mod listed on Gary's car. Should I do it?
Matt H
Re: TD clutch in 16v?
I thought it was the same anyway?
djoptix
If that's the case, that would certainly put me off doing the swap.
- x 94
3rd they are the same.
JayW
- x 13
I thought the TD clutch had stronger springs to account for the added torque?
- x 94
What, all 1lbft of it?JayW wrote:I thought the TD clutch had stronger springs to account for the added torque?
TD brings it in a bit lower, so if anything it'd need a harder-core friction lining, or better yet a bigger diameter if it needed to be any stronger. But with the expected use of a 16v being a bit more brutal, I'd expect that to have the stronger clutch. If they were different anyway
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Different clutch plate, but the mech is the same.
I must confess I thought it would of been the mech that's different, to give not necessarily a stronger clutch (as kitch says there's 1lb ft in it) but to give a faster gear change.
Not sure how the plate is different
- x 94
Clutch plate could be different between brands rather than design. They both use the same part numbers, as long as they're BE3.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Citroen list the plate as different part numbers but doesn't differentiate between be1 or be3 boxes. I wonder why they use a different part number? Were all oe clutches Valeo?
Citroen list different numbers because they were different!
Not very different, but yeah, slightly more meat on the friction faces is all
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Try this simple list of part numbers to see the differences between cross over parts.
NB only covers diesel and 16v.
- x 94
Supercessions, that's all. Part numbers change when OE suppliers changed, or when they changed the format of the numbers. Things like that.BX Bandit wrote:Citroen list the plate as different part numbers but doesn't differentiate between be1 or be3 boxes. I wonder why they use a different part number? Were all oe clutches Valeo?
Ford are the worst. They change FINIS codes every 6 months on some bits. Total PITA.
