Pump clatter
Pump clatter
The hydraulic pump on the TXD seems to quietly clatter almost continuously, though it still makes the usual 'louder clatter' when asked to do something, like raise the suspension. Is it likely that a bearing or something is on its way out in the pump? I'm hoping it'll still managed to get me to Devon and back over the weekend...
I do have another pump (I still need to pay Jayboy for it!) but don't fancy trying to fit it this afternoon in case something goes wrong. The car is always very slow to rise, needing raised revs. Steering is fine though. Brakes are quite poor (by BX standards).
Re: Pump clatter
Post by Mothman »
I wouldnt worry too much about it Ian, the pump on my TGD had been doing that since i got her 7 years ago and hasnt failed yet despite doing 20k. If it fails, then worry.
Re: Pump clatter
more often than not it is air ingress cause's this,
it does realy need checking as it will damage the pump in time (who knows how long )
also what state is your accumulator sphere
Re: Pump clatter
Thanks Andy. I'll turn the stereo up!
Malcolm - acc sphere isn't the best. Tick time is about seven seconds. Replacement will hopefully occur next Friday with the assistance of one Mr M Fenwick.
Re: Pump clatter
any clattering in the hydraulic components is metal hitting metal,
you got your moneys worth out of that sphere then Ian,
i thought it were i that has Jewish blood :shock: :lol: :wink:
Re: Pump clatter
It's the one it was wearing when I got it. I do already have a replacement, but don't much fancy my chances of replacing it without a proper sphere removal tool.
Re: Pump clatter
Post by kiwi »
Blimey you notice the noise above the clattering of the TXD engine?
I got to say I love the sound of the Diesel TXD at 5am on a quite morning! The sound certainly makes it clear that while others are still sleeping at the weekend I am off to do some work...lol
1990 BX19 TZS Auto 06/11/1989
Re: Pump clatter
get yourself one of these Ian,
you will need the 300mm version
http://compare.ebay.co.uk/like/38046244 ... sbar&cbt=y" onclick="window.open(this.href);return false;
the only thing to whatch when using them on a BX/XUD accumulator spheres, it can foul on the triangle web/ledge on the crank case behind the sphere, all you do it place the chain at such an angle around the sphere it does not catch up on the web
