Controls
Modstox257
Controls
Post by Modstox257 »
Stupid question but dose the BX have a flash seeting for the headlights ? if so where is it ? :(
Andy c:
1992 Citroen BX Hatchback 1.9D (Red) FOR SALE !
1993 Vauxhall Nova Van 1.5D (Blue)
1977 Mini Clubman 1275GT (Brown/Blue ''Restoration'')
1968 Ford Anglia Saloon Deluxe (Blue ''Restoration'')
1989 Volvo 240 GL Saloon 2.0L non turbo (Blue)
1989 Citroen BX 16 Valve Phase 1 (White)
Re: Controls
Yes. Just pull the indicator stalk towards you. With the headlights on, pull towards turns main beam on, do it again to turn it off.
Re: Controls
It doesn't have a flash function when the headlamps are on, no. Just main beam like Dolly says, so you've got to put it on main beam and turn it off again quickly, two or three times (if you're trying to look like you're thanking someone) . Bastard annoying too! That and the rear wiper switch setup on a hatchback. Crazy!
Modstox257
Re: Controls
Thouht so i just couldnt work out if it had one :') cheers guy's
Andy c:
Re: Controls
Bit advanced that for a time Citroen had just got into self-cancelling indicators for the BX! :wink: :lol:
kieran.l
Re: Controls
Post by kieran.l »
Way2go wrote:Bit advanced that for a time Citroen had just got into self-cancelling indicators for the BX! :wink: :lol:
But the mk1s do have a switch for flashing the headlights don't it? A push switch at the bottom of the left pod. But I'm not sure if you can flash when the light switch itself (slider) is switched to the off position.
Kieran
1984 BX 19RD
2018 Peugeot 3008 1.5 BlueHDi EAT8
Re: Controls
They do. Bottom of other stack does the horn. Believe you can flash with headlamps on or off.
2CV doesn't have a flasher, but it does have a 'mist function' on the wiper button, which is pretty advanced for a button. A shallow press gets you one wipe. Push all the way to turn them on.
