rust glorious rust-the saga continues badly
65 Peugeot Boxer work van 280k - x 121
my tzdt seems to have some serious rust issues around the tailgate (hatchback) on the n/s, its on the sloping pillar on the rear quarter that the gas strut attaches to, a few paint bubbles have turned into holes along the channel and down to the rear light panel which is also quite rusty, it seems that in the past water ingress has caused damage to this area, after wire brushing these areas i have been left with rust holes along the seam where the rear panel (the one that hides under the rear bumper) meets the rear light mounting panel, and also at the top of the rear light panel, and looking inside the wheelarch there is nothing left of the metal panel that covers this area, also the rear bumper support strut that goes from the boot floor side to the outer arch has completely rusted away, has anyone else had rust in these areas? will try to post some pics.
1987 Citroen BX 17RD - x 103
Re: rust glorious rust-the saga continues badly
I reckon the outer arch to boot floor support strut is what's rotted out on Stripey, meaning you can move the wing behind the bumper. There was a picture somewhere of someone's BX that had this bit welded back in, but I can't remember whose car it was, didn't look too complicated a repair.
i will repair it but just wondered if this was an issue with anyone else?vulgalour wrote:I reckon the outer arch to boot floor support strut is what's rotted out on Stripey, meaning you can move the wing behind the bumper. There was a picture somewhere of someone's BX that had this bit welded back in, but I can't remember whose car it was, didn't look too complicated a repair.
I'm wondering if it's related to the exhaust. The offside on Stripey is in pretty good shape, but the nearside is pretty bad and it's not the first estate I've seen that's got the same sort of pattern of corrosion. There seems to be a lot more muck kick up on that side too, so perhaps there's something going on under the car that causes this?
yes im sure with that strut support missing that a lot more crap has been thrown up into that area, will consider making a splash guard out of some old front plastic splash guards after fitting a new fabricated strut support.vulgalour wrote:I'm wondering if it's related to the exhaust. The offside on Stripey is in pretty good shape, but the nearside is pretty bad and it's not the first estate I've seen that's got the same sort of pattern of corrosion. There seems to be a lot more muck kick up on that side too, so perhaps there's something going on under the car that causes this?
I've not come across the rust in the rear pillar before, but rot in the rear panel and light surround on hatchbacks do seem quite common, usually accompanied by rust in the rear of the boot floor and in severe cases the inner wings too.
The bumper supports in the rear arches are a common problem - they'd completely disappeared on the 14 I had. Mat Fenwick has replaced these on his estate in the last few weeks, using some heavy bar that should outlast the surrounding metalwork.
It's a slightly different structure on the estates, but I also had the structure under the rear lights go quite badly on mine - have a look on the 'Timex' blog for pics.
The rear hangar for the exhaust is known for breaking away from the inner wing, but before it does that the cracking it causes first can lead to rot in the inner wing.
I'd be interested to see the pics when you get them sorted.
