N/S manual mirror mk2
- x 94
Anyone got a spare? I can swap for an electric one if needs be!
Re: N/S manual mirror mk2
Im sure I have kitch, wont be over to the lock up for a few days.
- x 94
Kitch, there's a couple of cheap new ones on E-bay !Kitch wrote:Anyone got a spare? I can swap for an electric one if needs be!![]()
One for only £7.95 which is made by 'Lucas' however the casings are made from a 'thermo-setting' plastic which are not as good as the OE ones (Britax) which are made from a 'thermo-hardening' plastic which are much better IMHO and the other listing is £8.45 but don't state the manufacturer !
So I'd go for the £8.45 as it may possible be a 'Britax' make (As they state it could be a OEM) or call to check the make (01732 810224) hopefully there better than the 'Lucas' unit but if you need one in a hurry its not a great risk at those prices inc. of delivery to your door !
hilarystone
I have a NOS Citroen one too which I won't use...
Hilary Stone
http://www.Hilarystone.com
- x 94
I need a mirror fairly quickly, but I've just found I've got two N/S electric ones in the shed so I'll likely just bung one of them on for now and grab a manual one off someone at a later date
