currently struggling with diagnosis of unknown fuel system problem
I have a bx17 tzd non turbo h reg
when the fuel tank is completely full, the engine runs smoothly, the idle is fine and acceleration is fine.
However once down to 3/4 tank or less i experience problems with running which gradually increase the less fuel is in the tank.
when idling the engine cuts out randomly and can be heard to struggle.
power is not consistent when accelerating
power is signigicantly reduced when going uphill as are the random cutting out problems
So far i have taken out and checked the pick up pipes, changed the fuel filter, put some diesel addative in the tank to clean the injectors, checked the fuel pipes for leaks and changed the leak off pipes.
I am going to nip to vanny's where we are going to blow out the fuel pipes and hopefully the pump.
Has anyone had this problem before? Anyone any ideas/suggestions?
Fuel system problem
mrmrwray
Fuel system problem
In Billy's old diesel and still going strong!
sleepy0905
I'd try lifting the back seat up and getting out the gauze filter in the tank. It could be blocking but if is not you've eliminated one possiblity at no cost.
I found this problem once on a 17tzd, turned out the filter was caked in, almost a wax substance which prevented the fuel getting through once the tank started to get anywhere near half full.
Terry Brooks
- Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
I've got similar probs with my 1.7 Turbo .....poor starting?,erratic tickover?....I've no idea whats causing it but I have found that by pressurising the fuel system with the primer the problem disappears ....I suspect air getting into the system somewhere....I will get 'round to sorting it out when the weather warms up a bit.....but in the meantime try parking the car facing downhill if the tank aint full,seems it stops air leaks.
HTH
Terry
HTH
Terry
