E-bay Seller wrote: Hi, This auction is for my Citroen bx tzd turbo, i bought it about a year and a half ago, when i got it it had no mot and had been standing for two year without use, i had to get a new hight corrector fitted for its mot as the old one was leaking a bit, other than that it went straight threw without problems, since then it was used up until just after December last year in that time i covered 12000 miles trouble free, i stopped using the car because it started to develop a noise that sounds like the passenger drive shaft, after closer inspection it seems that the diff is noisy, the car still drives smooth with suspension soft and working as it should, it started up first time today after being stood since December.
this car is far to nice to break or scrap, and i just don't have the time to do it, for someone who knows how to do it will know it can be done easily in a day with a few cheap bearings, or you could get it reconditioned for around £200
only bid to buy if you are capable of collecting and paying cash for the amount you win the auction for, i have been messed around in the past the car is how i have described it, if you want to view to see for your self just ask to arrange a viewing, before the end of auction.
the car is advertised else where and auction may be ended early.
any questions welcome thanks 07775423713
Needs a nice set of GTi/TZD Turbo or 'Z' wheel trims to cheer it too !
Click on any photo for E-bay link
Does this one belong to a forum member by any chance ?
If so good luck with the sale !
