Does anyone know how long it will take to change the rear H/C as mine is seized also i have got to replace the part that is called the "Reversing Lever" in the haynes manual as mine is absolutely knackered but what i want to know is in the book it shows the lever with notches L1 L2 but the replacement one i have has no notches in it is this normal and if not does anyone have one i can have.
Are you sure it's not just stuck? I've only ever had to change one of these and thats because it was leaking.
There is so little movement on the piston itself, they can easily sieze up, I think I'd try getting under there with a large can of WD and get your youth to sit in the cab and work the lever back and forth for ten minutes or so. Once freed up and good dose of spray on grease should keep things in order for a while. (a Xantia trick)
Before i start the job has anyone any ideas of adjusting the rear ride hight without a pit as i DONOT want to be layed under the car while playing with the ride hight or is it a job that can only be done over a pit.
I have done them with the rear end on ramps, its just a little alarming when the thing hisses and comes downwards, small adjustments and allowing the car time to settle seems to be the key.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Right well i have studied the exploded diagram and read all the literature on how the H/C works now if the dash pot or damper valve is blocked with crap then that will make the suspension hard as there is nowhere for the Lhm to go from chamber c or d so the piston cannot move does anyone else agree with my theory
A blocked height corrector cannot make the suspension go hard, as the height corrector only adjusts the volume of LHM in the system overall. Suspension movement due to bumps etc is taken care of by the sphere, and nothing else.
Most of the time, the HC is in it's "closed" position, thus having no effect on the suspension.
Oh bugger i wonder what else can be causing the hard rear suspension then as the spheres are brand new and i have checked them on the front so they arnt duff ones Hmm now i am any ideas anyone
Arm bearings are fine and the ride hight is out a fraction but not by enough to encounter the bump stops this one has me very even with the car parked up you stand on the tow bar it only moves about half an inch it is very hard.
Sounds mechanical to me - bits that could be concerned are the trailing arm bearings and the struts themselves. Since that trailing arm bearings are OK then are the struts OK.
Isn't there a problem with the pistons sometime? I'm sure I've seen something somewhere about this? - does anyone know?
