Hi,
Just had a call from the garage: Citroen bx 17 DTR '88
Main hydraulic pump leaking
Steering valve leaking
Fuel pump leaking
Front of car qumileter (is that spelt right? What is it?) valve leaking
I'm after a main hydraulic pump please anyone??
CHRIS
wanted : main hydraulic pump
- Tim Leech
- x 141
Re: wanted : main hydraulic pump
Accumulator (sphere), easy job, just needs replacing, pumps rarely leak but it has done alot of miles.
Tim,
It would be a pleasure to meet a seasoned Bx-er. Even better if you could show me what's what and what to look out for.
I will PM you.
I will PM you.
- Tim Leech
- x 141
Ok buddy, this weeks mad busy though.
Tim,
The bx is in the shop all week. Euro cars are replacing the hydraulic pump courtesy of the AA. So no rush fella. Appreciate the offer anyhow. When clarifying the problem with the front accumulator. It's the actual valve behind the shpere that's leaking? Are they cheap and easy to replace? The niggly bits he mentioned I'm hoping to sort myself.
If I'm to become a Citroen enthusiast. I need to learn a few D.I.Y skills.....
