Seeing Jaba's pics of his self-detaching rear subframe mounts has made up my mind that I'l take advantage of the white one being up on the ramp to strip it all out, blast the subframe, rustproof, paint, fit new mounts and arm bearings and re-pipe the whole rear end at the same time.
Trouble is, that wasn't part of the original plan, and I've got the whole front end in bits as well - struts, wishbones, hubs etc all out. So I can't pressurize the system in order to crack off the rear spheres....
So.... is there a way of cracking the spheres with the system unpressurized, or do I have to wait 'til the front is all back together, then pressurize, then start dismantling again? All suggestions gratefully received....
Rear subframe removal
KevR
JayW
- x 13
Re: Rear subframe removal
The rear spheres can be reomved unpressurised.
As the cylinders are loose in the mounts you can pull the cylinder across so the pipe union will lock into the hole on the side of the mount. Then you can wind the spheres off.
But, you don't need to remove them to get the subframe off.
KevR
Thanks for that. I want to take the cylinders out so I can blast/paint the subframe and swing arms, as well as checking over the cylinders themselves.
djoptix
The HBOL is full of dire warnings about removing anything on the hydraulic system without depressurising so I think you're OK...
KevR
The problem at the rear is that if the system's not pressurized then the cylinders can flap about and get damaged as you try and crack the spheres off. It's better to crack them fractionally with it pressurized, then de-pressurize before actually removing them. In the past I've completely mangled a cylinder trying to get it off an already-dismantled subframe - didn't want to risk doing the same with this one!djoptix wrote:The HBOL is full of dire warnings about removing anything on the hydraulic system without depressurising so I think you're OK...
djoptix
Ah, fair enough. And a useful tip!
