Auto to Manual swap
Auto to Manual swap
Got this crazy idea to use the TZS gearbox and clutch plus all the other gubings on the TZS Auto!
Why because I have a susp the gearbox is not long for this world and the Manual is in good nick.
Anyone done this swap and what problems did you encounter?
1990 BX19 TZS Auto 06/11/1989
Re: Auto to Manual swap
Have a search on this forum. It's been done before for sure.
i did one a few years back and it was not much more difficult that doing a clutch and pedal box really
Really dumb question about to be said.
When I (if) do the swap can I use the same good clutch or would I need to get a new one?
kiwi wrote:Really dumb question about to be said.
65 Peugeot Boxer work van 280k - x 136
i have recently done this on my tgd the auto box was dead and i changed it to manual quite simple to do, you will need a flywheel, flywheel bolts (as manual ones are longer) clutch kit, pedal box, clutch cable, gearstick and all the linkages including the ball pivot that sits on the top of the steering rack, new driveshaft seals, clutch plate inspection cover, hydraulic pump bracket, you will also need to rewire a few electricals such as reverse lamps and auto gearbox lockout switch, this was the case for a 1.9n/a diesel the driveshafts are same auto/manual, all fairly straightforward and just spannering, would advise the pedal box and clutch cable can be a bit fiddly, its prob easier to remove the complete eng/box together if u have the equipment, this also makes it a lot easier to fit and line up the pedal box and clutch cable. have done about 6000 miles in mine since converting with no issues just had to re adjust the clutch after 100 miles or so. and yes a new clutch false economy not to but thats your call.
yea I said dumb question just working out the cost effectiveness of the idea.citronut wrote:
The idea of removing the engine gearbox together is not an option. Couple of reasons both cars are 19TZS and both have Aircon fitted so remving the engine would result in added cost of the aircon regassing. Second reason is the Engine on the donor is stuffed or pretty close to being stuffed so would be a false economy.
So yes I have an entire car full of usuable gearbox parts to transfer over so by the sounds of it its just basically a Clutch replacement. Reason for the dumb question was would I get awy with using the donor cars clutch even if it dont last long.
aaaah i see i thought yoou ment re/use the clutch from the Auto
depends how much life the clutch from the manual car has left, otherwise that would be false economy,
- MULLEY
Don't be tight, fit a nice shiny new one There would be nothing worse than having to fit a new clutch only a couple of years down the road, so it makes sense to fit a new one. Out of interest, how can you tell how much wear an old clutch has had & how long it will last?
- mat_fenwick
- x 19
Just unbolt the compressor and support it out of the way, that is if you wished to remove the engine too.kiwi wrote:both have Aircon fitted so remving the engine would result in added cost of the aircon regassing.
New clutch, release bearing and crankshaft seal is a must! (new clutch calble is also advisable)
Access to Steering and brake valve is also a lot easier when there is space!
the haynes manual will give u some guidance as to wear limits on the clutch plate, , but bear in mind sometimes the pressure plate can be at fault which is usually the case with recon clutch kits, (they are rubbish dont buy one) many types of clutch available on ebay here from about £20 upwards some NOS, as i got for the tgd NOS valeo £30 not sure about your spares availability in nz tho. as mulley says a nice shiny new one would be the way to go, you only wanna do the job once, dont you? i used a suitable piece of timber or bar across the slam panel and bulk head, fix a ratchet strap to this and the other end of ratchet strap to the lifting eye on top the gearbox will assist with lifting the box from the floor into place unless you have other help, you will also need to bypass the water cooling unit on the auto box or just join the hoses together, removal of the radiator does help as you can then push the flow dist valve out the way and makes it a lot easier to get the gearbox in.
- mat_fenwick
- x 19
True, but taking the gearbox out won't help on a RHD carbx_pallas wrote:Access to Steering and brake valve is also a lot easier when there is space!
Haha! I totally forgot you dont have any padals there! But don't they have LHD BXs in New Zealand anyways?mat_fenwick wrote:True, but taking the gearbox out won't help on a RHD car
Take one RHD clutch cable and you can make three LHD ones out of it!
