Can anyone help?
I've got a couple of bits which my version of the Citroen EPC doesn't recognise....
First is a bag of wave washers no: family number 1XB (so must surely be BX) 7903 057 070
Second is what looks like a front wishbone through-bolt, but its not the same as the ones on my Mk2 (mine have a keyway to locate a washer, these don't).
Family no: 3, part no 95 565 793
Can anyone identify them?
Probably got loads more unidntified stuff lurking in the shed...!
Identifying parts from numbers
KevR
Re: Identifying parts from numbers
neither of those numbers work on service citroen
http://service.citroen.com/" onclick="window.open(this.href);return false;
KevR
Strange - they're definitely genuine Citroen bits, in original packaging, and I've double checked the numbers! Maybe they're older numbers that have been superceded or aren't made any more (although in either case I'd have thought they should still come up).
i belive citroen are deleting BX parts from there data base,
do you recognize the parts you have,
if not can you post photos
