Hi all,
I have one or two used heater valves/pipes but I'm after a new one if anyone knows where I could find it?
Best,
Chris.
Heater tap/valve
Heater tap/valve
1989 Citroën BX 16v
1993 Citroën BX 16v project
Re: Heater tap/valve
I guess this one goes on the list with tail blazers, sunroof wind deflectors, head lamp protectors, ph2 16v rear mud flaps, GT cardboard intake pipes, abs sensors and digits!
1989 Citroën BX 16v
So has anyone engineered a substitute heater tap that might work? Surely there is something that could be made to fit?
Michael, Sydney, Australia
BX19TRI Automatic
DS23 Pallas
BX19TRI Automatic
DS23 Pallas
It's the top plastic pipe that breaks off on all the ones I've seen. I was thinking I might sleeve the inside of a good spare one with some metal to strengthen it. A new one would be easier though.
1989 Citroën BX 16v
