Just bought a new Solex Z1 32/34. Im confused as to what this extra diaphragm is for on the front, below throttle cable bracket as its not fitted to the carb curently on my car.
Any ideas?
Thanks.
Matt.
It appears to pull againts the throttle mechanism, which would back up your suggestion of its purpose. I know what you mean about 2cv carb as I've got a Dyane back at my home in N. Ireland (currrently reside in Glasgow).citronut wrote:it might be and anti flood/strangle capsule,
similar to a dersh ( 2CV ) has,
you should be able to tell what it does firstly by following the rod at the back of it,
or attach a length of pipe to the spout and suck on the pipe whilst watching the mechanism,
ps.
hope you dont get grease on your mums sofa![]()
kiwi wrote:I forget what the thing is called but it is on the Aircon models and is part of that function I am lead to believe. I know some fiddling with it while running the aircon on adjusts the idle.
It IS fitted to both Aircon models of my 19TZS fleet but not fitted to the 19TRS infact I have never seen it fitted to any other BX petrol unless its got aircon.
Will have a look tommorow for you to see how it conects and if you can indeed not bother with it, my hunch is you dont need it.
It was common at one time to operate aircon components (pump clutch, coolant valves etc) by a vacuum switch in the dash. In this case the vaccuum (switched to that port when the aircon is switched on) is obviously used to change the idle setting on the carb so the car doesn't stall when the aircon is running and adding a small extra load on the engine.I looked on the 19TZS with it fitted and it is part of the aircon.
