This is the correct temperature transmitter for the BX with temperature gauge...
http://www.ebay.co.uk/itm/151044992377? ... _177wt_725
Temperature transmitter
electrokid
2002 C5 HDi SX estate
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Temperature transmitter
Not sure if you're asking or telling? It says it's a switch and I think (although happy to be prooved wrong) that single terminal ones are switches whereas guage type ones have two terminals.
RobC
- x 30
Gauge ones only have one terminal too. Temperature probes for the ECU have two terminals though!
That looks like a switch to me as well: the 'sensors' for gauges tend to have a longer probe.
1991 Citroen BX 16v
You're wrong!BX Bandit wrote:happy to be prooved wrong
EDIT - crossed posts there with conflicting advice
EDIT 2 - I'm referring to the body of the switch/sender being taller, not the probe part. Will still check though!
RobC
- x 30
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Several lashings of a I shall give myself, swiftly followed by muchos of thisos:
Pub Quiz Question: Who is the sole influence behind that wine /\ smiley?
Hmmmmmmmmmmmm, I wonder
JayW
- x 13
Does it start with an "M" and end with a "Fenwick" (and a headache)?
I can confirm that the part with the long housing is the switch, looking (from the outside at least) like the one in the eBay photo. I'm guessing Brian has bought one which is why he's able to confirm this is the right one?
Oh, and cheers!
electrokid
Spot-on MatI'm guessing Brian has bought one which is why he's able to confirm this is the right one?
If you are modifying your instrument pod to include the temp gauge from the GTis and 16v etc then this is the bit you need to make it work. This particular part number reduces it's resistance to almost exactly 130 ? at 100°C. Coincidentally, the temp gauge reads 100° when it's connected to ground / chassis / 0v through a 130 ? resistor. The transmitter I bought from a Citroen dealer was not as accurate - having found a part that worked properly I added it to my eBay searches - this is the first time it has come up since then so if you need this sensor I'd grab it while you can.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
JayW wrote:Does it start with an "M" and end with a "Fenwick" (and a headache)?
My thoughts exactly, although he's declined to comment.
Sorry electrokid, it just goes to show you shouldn't listen to a wino like me
But, as I'm adding guaging, then I shall purchase forthwith! Good heads up mate.
crb
- My Cars: BX 1.9D Meteor
Saab 9-3 1.9TD Estate
Thanks for posting this - just ordered one - will finally get round to fitting the temp gauge to my Meteor.
Colin - Returning to BX's for the challenge.
BX19 TGD Meteor 1991
electrokid
No worries at all - always best to make sureSorry electrokid, it just goes to show you shouldn't listen to a wino like me
