Headlamp gumph
saintjamesy89
1990 Volvo 740 2.3 GLE Estate
2013 Nissan Leaf Acenta 24Kw - x 198
Headlamp gumph
Hello all,
I changed my headlight bulbs this evening to discover they bulbs were fine, but the connector metal (three prongs) were quite corroded due to exposure, as the plastic plugs had melted away at there very ends and on one of the prongs entirely. Asso is there supposed to be a rubber cover for the back of the headlamp unit? There is not one of these either. If anyone has two covers, that'd be great!
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
Re: Headlamp gumph
Not noticed any rubber covers on the back of any headlamp unit of a BX I've ever owned.
Re: Headlamp gumph
Same here.
Re: Headlamp gumph
you need these or the likes
http://www.amazon.co.uk/dp/B009XAAEA4" onclick="window.open(this.href);return false;
Re: Headlamp gumph
Can't remember seeing covers on BX lamps, although if you wanted some I'm sure you could find something suitable in the local scrappy.
As for the connectors, they are standard H4 units which are readily available
electrokid
Re: Headlamp gumph
Or if you have changed the bulbs for higher power (not road legal) 100/80 or similar you might need these...
http://www.ebay.co.uk/itm/H4-CAR-HEADLA ... 2660wt_725
2002 C5 HDi SX estate
Re: Headlamp gumph
Never had covers on any of the cars that i've owned & i've never seen any in any of the engine bays of other cars that i've looked at over the years.
Re: Headlamp gumph
I've seen them on GS's and Ami's.
- Reluctant BXpert
Re: Headlamp gumph
OK, I REALLY need to get a better job. I'm finding this thread utterly hilarious.
Never mind, carry on/talk amongst yourselves.
saintjamesy89
Re: Headlamp gumph
I think the consensus is that they never had headlamp back covers then? Only asked cos my astra had these, nice thick rubber covers that sealed the headlamp unit from dirt/water etc - a good idea given the way mine have corroded on the TXD. I'll have to get some nice new H4 connectors then. Thanks.
I went for halfords +50% light output ones, still legal.
Re: Headlamp gumph
The Astra being a German design. They take these things VERY seriously! On my W124, there's a large plastic cover, with seal held in place by two clamps. Mind you, I seem to recall changing bulbs on my Renault 21 was complicated by some sort of protective gubbins - whereas changing a bulb on a BX takes mere seconds.
