Retrofitting electric mirrors
Phil Peters
Post by Phil Peters »
Hi all,
Is it possible to retrofit electric mirrors on a MK2 hatchback? If so, is it a case of simply plugging into the car's existing wiring harness or am I looking at spending some quality time with the soldering iron?
Cheers,
Phil
1992 BX19 TGD (aka Maurice), N/A diesel, silver with Zenith trim.
KevR
Re: Retrofitting electric mirrors
Post by KevR »
Pretty sure you should be able to plug into the harness. Easy enough ti find out - if there's a suitable plug hanging spare up behind the switch blanking plate near your right knee, then that's probably a giveaway! Same in the door - look for a spare plug up near the mirror mount.
I wouldn't bother for the driver's side - actually takes longer to adjust than using the manual lever...
x 17
Dunno if the loom is present on all models, but only the ones fitted with dual mirrors had the capability to adjust both sides separately. The mid range models with a passenger side mirror had the wiring present but both sides will operate simultaneously from the switch, presumably to cost costs by not having LHD and RHD specific looms just for a passenger mirror. It's fairly simple to modify the loom and switch to operate both as they should be - check out the thread in Tech FAQ.
My Cars: too many....
x 125
If it a car that came with manual mirrors both sides there's no wiring loom so you will have to get one.
Tim Leech wrote:If it a car that cane with manual mirrors both sides there's no wiring loom so you will have to get one.
Getting the switch unit and mirrors will be the important part. It's probably easier to make up the wiring new yourself than the aggro of unthreading it and extracting it from a donor.
Post by Mothman »
Recently removed the entire wiring loom from the scrapper, not a job i would like to do again as it didnt come out easy and the thought of putting it back scares the hell out of me.
x 17
Way2go wrote:It's probably easier to make up the wiring new yourself than the aggro of unthreading it and extracting it from a donor.
Very true. Especially as it would have to be a 16v (or GTi?) to work both mirrors without modification. The loom for the mirrors passes diagonally under the driver's footwell and underneath the seat towards the centre console, and is bundled with several other (helpfully also green!) wires...
Phil Peters
Many thanks for the info guys. Another job to add to the list, albeit under the "Low priority / Shouldn't you do the more important bits first?" section.
Cheers,
Phil
x 26
I have a drivers side electric mirror I would sell if you need one.
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
Can you elaborate, I have joyous task of removing my TZD loom to put in the TGD!
Post by Mothman »
To be honest bud, i just took the entire thing out of my scrapper TXD in one big lump of muddled wires, some of which i had to cut as it resisted a bit and didnt give up easy.
Took a long time to disconnect everything that i could. I suppose it was a bit easier having the body upside down with everything removed, including all trim and insulation but i wouldnt want to refit the damned thing. There were many single wires dissappearing into small holes which were just cut so i dont envy you.It would be well beyond me to take out a loom and re fit it. Why are you doing it?
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
2 reasons really,
1) to convert a TGD to TZD spec
2) to transfer the a/c loom (don't know if this is a separate extra loom (suspect so)) which is in the TZD to the TGD
ergo TGD transformed to TZD with a/c.
Post by kiwi »
Not such a daft idea really! Since the TZS is pretty much beyond economical repair. I also have all the parts and a rather boring TXD with no electric mirrors, door warning lights, rear electric windows (not worried about them) and a aircon system. Since I also have the wiring loom going down the path of considering fitting these one day. Saves the parts going to waste.
1990 BX19 TZS Auto 06/11/1989
