I have managed to aquire a repair kit for the rear height corrector, from Martin at Pleiades. The kit comprises off two identical type dust covers, one diaphragm with no centre hole, one diapragm with a centre hole, two identical metal 2 1/4 " ring clips and three LHM pipe end seals.
Today with the rear of the car on axle stands and the front on the floor and with the exhaust system lowered onto the floor, I managed to satisfactorily remove the rear height corrector. I have said corrector in the vice.
I have managed to remove the 8mm nut, cup washer, dust cover 1, metal plate, spring, circlip, and the flat washer. This is exactly where I am upto as of now. I have figured out that the diaphragm with the centre hole in, fits on the rear of the height corrector where the rod comes out of the back of corrector body.
The problem I am having is that there appears to be a large diaphragm still happily seated in the rear of the corrector body, that I can,t seem to manage to move at all,( I don,t want to pull it out any further as it seems to be not shifting at present ) and I don,t want to break anything.
The second problem I am having is that I haven,t seem to found the second diaphram, the one with no centre hole.
The third problem I am having, is that I have managed to fit the most rearward diaphragm, the one with the centre hole, which is a little fiddly, but I seem to have no chance at all of fitting the new metal ring.
Any help or guidance would be gratefully appreciated
Vince,
