It's approx a fist sized amount of damage, right at the bottom of the screen (i'm guessing the strongest part?), its actually damaged the outer layer so much that you can see how deep it goes & its even punched the glass through to the inside of the cabin, so its mullered.
Typically its in the wiper blade sweep area so it will kill the wiper if i use it & i also don't want rain to get inside the damage. Has anyone got any suggestions for a temporary repair, i was thinking of either using paint laquer to seal the damage up or try using some clear builders caulk to the same effect. Will either of these work or is one a better temporary solution than the other or does anyone recommend something different?
Knowing my luck it'll be raining when i leave off work today
I'll put up a seperate post about trying to get hold of a replacement screen etc & whether its worth doing it via the insurance or not, so don't post anything about this rubbish on this posting please, i'll create a seperate one in a bit.
Cheers everyone.
