a Red 19 TXD, reg K125 UBV, for disposal
pmh
Post by pmh »
Following some exploring of the front inner wing rot I have decided to give up on K125 UBV.
Pity because mechanically pretty good and remarkably lively for a a non turbo!
It will go for scrap (£140) unless somebody can make an equivalent offer - I am not in a position to break it.
Also needs an alloy thermostat housing - corrosion - it is out of coolant so cannot be driven other than move around driveway.
SORN and will need a trailer to get it away in the next 3 weeks.
If you wish to look at history see
http://www.bxclub.co.uk/forum/viewtopic.php?f=5&t=10049" onclick="window.open(this.href);return false;
http://www.ebay.co.uk/itm/1992-CITROEN- ... K:MEWNX:IT" onclick="window.open(this.href);return false;
BX4X4X2
Re: a Red 19 TXD, reg K125 UBV, for disposal
Post by BX4X4X2 »
Hi, whereabouts are you based?
Post by RxBX »
BX4X4X2 wrote:Hi, whereabouts are you based?
pmh wrote:Having made some investigations into the inner wing rot I have now decided to abandon this car as a project.
And the wife wants it off the drive.
I have started to cut out the inner front wings and also discovered that the thermostat housing has a pin hole leak (corrosion of the al body.)
Seems a pity because mechanically it was in good condition.
Anybody interested ? South Herts. SORNed,Will need a trailer as coolant has now escaped.
Scrap value collected £140, but may consider (slightly) less from someone who has the time and enthusiasm !.
/\ quote From the other THREAD :wink:
Good luck with it if you can save this one !
Easy fix for someone with the skills? looks a tidy old thing and would of course polish up well.
Vince Pepper
My Cars: 1989 PH2 16v. White
Seat Leon FR. Whiter
Post by Vince Pepper »
thought I would bump this in an effort to save it from the scrappy,
I took a look at this on Friday, its a nice straight car but a bit too much work/time for me to take on at this time, Peter has cut out a large area of rusty metal from the n/s inner wing, the aircleaner and other bits have been removed for easy access to the whole area, on the o/s inner wing is a much smaller area of corrosion which hasn't been cut back yet but could prove much more fiddly to repair with the hydraulic tank and pipes so close, the o/s sill at the rear is a little crunchie, so some work will be required there in the near future if not for mot, the engine is sweet but will need a replacement fuel filter body as the alloy base has perforated letting water leak from the thermostat housing, the interior is nice and tidy and the car looks great in Red, I hope someone can save this in the next week or so.
pmh
Post by pmh »
Vince - thanks for that - it does benefit having an independent view!
the fleabay listing suggests
Bridgwater, Somerset
pmh
Post by pmh »
As above and in the other thread!
Anybody interested ? Situated in South Herts.
